6/29/2015 4:43 PM | |
Joined: 8/25/2005 Last visit: 1/29/2025 Posts: 1162 Rating:
Hello Mo.Sa,
I havn't done such a configuration. But I think it should work. Within your PLC the Device must be configured. Please check this document to make the device availabe within your configuration: What can you do if required modules are missing in the module catalog of the STEP 7 hardware configuration? Good luck |
3/11/2016 3:52 PM | |
Posts: 63 Rating:
dear mojtaba this is your way , look at the page 23 carefuly . but i know undrestanding the complete concept of relation between actual address and slave address is very complex . if you want an specific information ask me in here . also siemens provide this : https://support.industry.siemens.com/cs/document/51678777/convenient-command-interface-for-central-and-distributed-as-i-master-for-as-interface?dti=0&lc=en-WW Hess AAc Software Specialist .saeed bahadori Attachmenten_compact_manual_profinet.pdf (291 Downloads) |
