9/10/2008 10:43 AM | |
Joined: 9/27/2006 Last visit: 5/27/2023 Posts: 12022 Rating:
Hello BVV; Can you live with a descending order? Siemens provides a downloadable function for a variable-size DBsorting procedure, but the results are given from lowest to highest value. The code comes with it, so you could study it and modify it, if you are at all familiar with STL; or you couldpossibly transfer the results in your work DB in the order you need. Have a look here: http://support.automation.siemens.com/WW/view/en/865058 Hope this helps, Daniel Chartier |
9/10/2008 11:29 AM | |
Posts: 12 Rating:
Dear dchartier, |
9/18/2008 5:53 AM | |
Posts: 12 Rating:
Dear DChartier, Problem solved. Thanks for your support. Regards, BVV |
9/27/2008 12:26 PM | |
Posts: 12 Rating:
hi Daniel Chartier, sorry for the delayed response. please find the working program. Best regards, BVV AttachmentSort Algorithm.zip (196 Downloads) |
