4/5/2017 1:34 PM | |
Posts: 16 Rating:
1SI Modbus/Uss controller 6es7-138-4df010ab0 ET 200s CPU I'm sending the messege from and array of bytes with $01P1<CR> written hexadecimally and i'm using the S_Send and S_RCV-function blocks AttachmentPictures.zip (833 Downloads) |
Last edited by: Kim86 at: 4/5/2017 1:41:09 PMLast edited by: Kim86 at: 4/5/2017 1:42:31 PMLast edited by: Kim86 at: 4/5/2017 1:43:37 PM |
4/5/2017 2:13 PM | |
Posts: 16 Rating:
Byte sequence: 24 30 31 50 31 3c 40 52 3e ASCII-sequence: $01P1<CR> |
4/5/2017 3:59 PM | |
Joined: 1/17/2007 Last visit: 3/10/2025 Posts: 1557 Rating:
Not sure what calculations you are using there. The usual value of terminating resistors is about 120 ohm (or equal to the impedance of the cable). Plus 50cm seems a very short distance and shouldn't really need terminotors over such a short distance. You may find this link helpful http://www.bb-elec.com/Learning-Center/All-White-Papers/Serial/RS-422-and-RS-485-Applications-eBook.aspx. |
Programming today is the race between software engineers building bigger and better idiot proof programs, and the universe producing bigger and better idiots. |
