4/3/2009 11:14 AM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, Look at SIMATIC Maintenance Station
Also look a this Brochure Plant Asset Management Hope this will helps. Best regards |
4/3/2009 5:27 PM | |
Hi I thing, what you are looking for is Downtime Monitor and/or Prozess Monitor. Downtime Monitor: (excerpt from dokumantation getting started) SIMATIC WinCC/DowntimeMonitor helps you keep track of downtime periods and the performance of certain equipment units. This Getting Started aims to provide a step-by-step guide to the most common operations which can be performed with it.
regards |
Learn more about visualization - visit the HMI courses of Siemens AG! |
4/3/2009 11:21 PM | |
Posts: 33 Rating:
DowntimeMonitor is an OEE calculation tool and not really aimed at planned maintenance. Maintenance Station can give asset data of non Siemens components using the AssetProxy function block supplied. I believe this can be used for hours run and number of operations with alarms set for planned maintenance. For true planned maintenance activities take a look at the WinCC Add-On package PM-Maint. Details are available at www.siemens.com/process-management |
