5/22/2016 3:56 PM | |
Posts: 45 Rating:
Please help us into ,Atlas-Copco Compressor not coming online on profibus DP. (Bus Fault) We did following setting- From Atlas-Copco combbox gateway side a. Profibus active b. Slave Address =12 d. Data Record = 1 This combo box is mkv5 model in which DIP switches are not available on-board to set address and baud rate. From PLC Hardware side a.Configure though .gsd file received from atlas copco b. DP configuration Slave address =12 select = profi2can Select = Universal Module (input/Output) Check on baud rate - 9.6/19.2/1.15 same result as show into picture
Last edited by: Min_Moderator at: 5/23/2016 10:48:57 AMNew subject after splitting |
5/23/2016 3:51 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4812 Rating:
The second thread with the subject Communication in between ATLAS-COPCO Compressor and S7300 PLC is published within the conference Decentral Peripherie. Best regards |
