8/12/2020 4:26 PM | |
Hello you can do it by copying the LDF/mdf Files to the Folder "Common Archiving" then the Database segements will be attached automatically. And there is an example for scripting in a WinCC V7.X FAQ: https://support.industry.siemens.com/cs/ww/en/view/40347325 It should work in WinCC Prof similar. Bye Murof |
