11/18/2019 2:44 PM | |
Hello Here you find Information for Configuration of Audit in WInCC in TIA Portal: https://support.industry.siemens.com/cs/de/en/view/109766369 Only in WInCC Comfort/Advanced there is a build in Solution for the Audit Trail. If you work with a WinCC Professional RT then you have to do a non automatic solution. Bye Murof |
