4/13/2006 2:40 PM | |
Posts: 5822 Rating:
Hello Pavel, I guess I have a solution for you. Check this out, I guess this will work with your program. Just be sure that the OPC Server requires some time to startup, so offer him about 30 to 60 seconds to startup before your program tries to open the OPC Server: |
8/15/2006 1:43 PM | |
Joined: 8/10/2006 Last visit: 2/13/2025 Posts: 156 Rating:
Also you can use macro scheduler utility for automatic login and after task performing it will log-off. |
