1/2/2013 12:49 PM | |
Joined: 8/31/2010 Last visit: 2/1/2023 Posts: 1498 Rating:
SIMATIC S7-1200: AT 1 - Simple Movements Simple movements like clamping, turning and pushing can add complexity to any automation system, and this is especially true if you have many multiples of them across your factory floor. Unfortunately this can consume valuable engineering time. Watch Video - SIMATIC S7-1200: AT 1 - Simple Movements |
Like it? Rate it! |
1/2/2013 12:52 PM | |
SIMATIC S7-1200: AT 2 - User Defined Webpage User Defined Webpages can be invaluable tools for diagnostics and control on the factory floor. End users that have many remote automation systems can have greater transparency for all their systems directly on a smart phone/device. Watch Video - SIMATIC S7-1200: AT 2 - User Defined Webpage |
Like it? Rate it! |
1/2/2013 12:53 PM | |
SIMATIC S7-1200: AT 3 - GPRS to SMS Sending SMS messages that are event or application driven can be an excellent tool for end users maintenance staff. This is especially true if you have a down time event, and the automation system is in a remote location. Watch Video - SIMATIC S7-1200: AT 3 - GPRS to SMS |
Like it? Rate it! |
1/2/2013 12:56 PM | |
SIMATIC S7-1200: AT 4 - Simple HMI The ability to easily add an HMI to your current automation system can be a huge advantage in your engineering effort. This is because a graphically user interface makes controlling a system simple and intutive. Watch Video - SIMATIC S7-1200: AT 4 - Simple HMI |
Like it? Rate it! |
1/2/2013 1:02 PM | |
SIMATIC S7-1200: AT 5 - HMI to SCADA The ability to take your current HMI screens & Tags, and re-use everything for a plant expansion gives you scalability & flexibility that can be a huge benefit to any automation system. Watch Video - SIMATIC S7-1200: AT 5 - HMI to SCADA |
1/2/2013 1:04 PM | |
SIMATIC S7-1200: AT 6 - Distributed Networks In some applications it's more advantageous to use distributed I/O in order to minimize long wire runs, wire trace out for startup and trouble shooting time. That's why distributed networks give you scalability and flexibility to your current automation system. Watch Video - SIMATIC S7-1200: AT 6 - Distributed Networks |
Like it? Rate it! |
1/2/2013 1:06 PM | |
SIMATIC S7-1200: AT 9 - SIMATIC App Apps for an automation system have added benefits of both diagnostics and control - anytime and anywhere! Watch Video - SIMATIC S7-1200: AT 9 - SIMATIC App |
Like it? Rate it! |
6/21/2013 6:07 AM | |
Hello Kassem Harakeh, Refer - First steps of the wireless data communication with TeleControl Server Basic, video Also S7-1200 <--> Telecontrol Server Basic Communication (Set 30) temporary GPRS connection(Set 34) S7-1200 <--> S7-1200 Communication (Set 31) Teleservice using CP1242-7 Hope this helps. |
Like it? Rate it! |
