3/10/2011 2:33 PM | |
Posts: 344 Rating:
I believe that this is as simple as passing the Motor 1 speed setpoint to Motor 2. Option 1: You can bring Motor 1 speed setpoint r062 to Motor 2 as an additional speed setpoint prior to ramp function generator P1075 Option 2; Motor 1 speed setpoint r062 as an additional sped setpoint after the RFG p1160. Option 2 would probably work better for speed synchronization. You can still jog the axis manually utilizing RFG separately. I attached a file with screenshots for reference. AttachmentS120 Speed Setpoint.pdf (770 Downloads) |
3/15/2011 10:07 AM | |
Joined: 9/18/2006 Last visit: 2/1/2023 Posts: 578 Rating:
Hi. Thanks. I have many variants and I do not know what to choose. Denis, your opinion concerning it: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=48947154&caller=nl To me it can help me? |
3/18/2011 8:37 AM | |
Hi. Thanks you. I will try to make so. What your opinion? AttachmentSynchro drives .pdf (941 Downloads) |
