7/25/2008 1:10 PM | |
Joined: 8/31/2005 Last visit: 9/14/2023 Posts: 2194 Rating:
No, this should work fine.. Maybe you selected a telegram, that can not transfer encoder data, it's recommended to use Telegram 105. Did you select isochrone mode for the PD-Bus? Did you see this document? http://support.automation.siemens.com/WW/view/en/30119684 Do you use S7-Tecnology our Scout? |
