10/1/2014 2:47 PM | |
Joined: 10/11/2006 Last visit: 4/17/2025 Posts: 6008 Rating:
Hello, there is a FAQ for Axis simulation. http://support.automation.siemens.com/WW/view/en/53503767 Your way with a DCC chart sounds very difficult, because you have to provide the statusword. |
With best regards, |
10/2/2014 7:54 AM | |
Hello, you can use a Dummy PQW (e.g. telegram extension) to configure the hydraulic axis. For the encoder you can use "Encoder value via system variable". TypeOfAxis.numberOfEncoders.Encoder_x.encoderIdentification=SET_ACTUAL_VALUE
4/26/2018 10:12 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by Mohka is split to a separate thread with the subject Can transfer parameter of simulation axes without assignment drive?. Best regards |
