8/13/2015 2:41 PM | |
Posts: 4 Rating:
Hello Everbody, Is it possible to backup from the existing TP177A HMI and download to New TP177A by Prosave V9.0.3.0? its only showing TP177 Micro and TP 177 Micro (portrait) on dropdown menu. please help me out. * Note: The Existing HMI is not in my hand to test. Thanks in advance. :) ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 8/13/2015 3:18:22 PMNew subject after splitting |
8/13/2015 5:39 PM | |
Joined: 3/28/2015 Last visit: 2/1/2025 Posts: 722 Rating:
Hello, Upgrade the ProSave software and your problem will be solved. Servicetool SIMATIC ProSave |
Eng.Mohamed Ibrahim |
8/17/2015 9:04 AM | |
Posts: 4 Rating:
Hi, Is it possible to use Prosave v9.0.3.0 instead of upgrading
8/17/2015 10:06 PM | |
Hello, Kindly find the attached file. Check TP 177A panel in ProSave V9 If you find it,So this panel is supported by this version of ProSave. Sorry,I have the ProSave V13 only AttachmentRemark.zip (644 Downloads) |
8/18/2015 10:17 AM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello manoz, Should work this is with Prosave V9.0.0.0. Go to table 2-1: Operating System Update with ProSave - Services - Sieme |
8/18/2015 7:34 PM | |
Hello, Ste39 decide that ProSave V9 support TP 177A panel If you not find it ,may be a problem in your software and need to repair it. |
11/23/2015 10:22 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by Kshf is split to a separate thread with the subject Upgrade/downgrade of firmware of any TP's via USB?. Best regards |
