1/18/2009 11:39 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181) |
Hello, Look at SIMATIC HMI WinCC flexible 2008 (page 409) To make backup of OP, for you will be easiest to use Prosave. Also look what is possibilities to connect to the OP. Which cable can you use for data transfer between a Micro Panel and a configuration PC? + Which HMI operator panels support retransfer of the configuration? The last link shows different tools for making transfer and upload to/from OP. Look at notes under the table. regards |
