11/30/2024 11:24 AM | |
Joined: 5/15/2020 Last visit: 4/16/2025 Posts: 46 Rating:
Did you find any solution? |
12/12/2024 3:46 PM | |
Joined: 6/14/2011 Last visit: 4/14/2025 Posts: 7 Rating:
Hello, same problem here... Can't find any solution... |
12/18/2024 12:57 PM | |
Joined: 8/3/2009 Last visit: 4/24/2025 Posts: 15350 Rating:
Hello aatifshaikh66 check in the following Example: https://support.industry.siemens.com/cs/de/en/view/63481236
You have to trust the Client certificate in the specific folder, only then the certificate could work bye Murof |
