8/26/2021 9:40 AM | |
Joined: 4/28/2015 Last visit: 8/11/2022 Posts: 2897 Rating:
Hi, you can find some instructions in this thread. It is about the Example Image, but the procedure is the same. In your case, you need a USB flash drive with the Example Image on it to boot from it. Then insert the SD card with you backup image and write the image from SD card to the eMMc with dd. Best regards! |
Out of office until Thursday, August 11th |
