3/24/2014 8:41 PM | |
Posts: 8946 Rating:
Mark the FC and press F1 |
3/25/2014 11:05 AM | |
Joined: 9/23/2005 Last visit: 12/4/2023 Posts: 4281 Rating:
Hi, the S7-1200 analogic signal runs in a range from 0 to 27648 (or -27647 to +27648). You can build your block converting integer to real and after that multipling / adding constants. Some samples, like in (/tf/WW/en/Posts/31698) are open codes that do it. You can open the logic and take a look inside. It is not much to see there, and after that you can use or adapt your block to your necessity. |
Denilson Pegaia |
