10/21/2009 2:57 PM | |
Posts: 2348 Rating:
Just use OB81 in your programm) |
10/21/2009 5:13 PM | |
Joined: 5/28/2008 Last visit: 7/23/2024 Posts: 4514 Rating:
Dear Mubasshir, Generate OB81 in your software and hit F1 key to open the help of that OB and you will found in it the codes for all errors that that OB can cover. When The PS battery fault occure, the CPU calls OB81 if programmed, so you can generate an alarm to Scada system reporting that there's a battery fault. Regards, |
Ayman Elotaify |
