6/5/2008 3:39 PM | ||||
Posts: 124 Rating: (17)
I guess PCS7_id10t is right. For many years I used the FAQ below
But it's easier and fasterto use a new installation. Just do a disk image of your HD (only with Operational System), and then you install PCS7 packages. You can have .bat files to install the image (from other disk partition, D: for instance), then you installPCS7 from network (this is usefull if you have to install in many PCs a new version). And don't forget to remove the licenses or keep them in another disk partition (E: for instance). Regards. |
