5/14/2013 5:07 PM | |
Posts: 3037 Rating:
Hello, Which Runtime do you use? Advanced or Professional? http://support.automation.siemens.com/WW/view/en/634457 Tweety |
5/15/2013 3:45 PM | |
Posts: 3037 Rating:
Hello, You can use the WinCC flexible systemfunction "SetBitInTag". Tweety |
5/17/2013 1:49 PM | |
Posts: 267 Rating:
Hello, if your DB is absolut addressable I think you can do it on this way, or you perhaps the following link will help you: How can you group separate signals (variables of the "Bool" data type) to one variable of the "Word" type and again extract them from that "Word" variable (Bool - Word data type conversion)? or update your CPU to firmware V2.2 and do it with the slice access: Firmware updates for S7-1200 CPUs How in STEP 7 V11 can you access the unstructured data types bit-by-bit, byte-by-byte or word-by-word and symbolically? |
5/20/2013 11:36 AM | |
Joined: 12/9/2010 Last visit: 1/29/2025 Posts: 164 Rating:
Thanks alot! The bool to word I knew but the word to bool will be great! :) |
