10/11/2023 6:52 AM | |
Joined: 8/3/2009 Last visit: 2/18/2025 Posts: 14762 Rating:
Hello bruncekk Which TIA Portal Version do you use exactly? do you have set up your Certificate authority in Certificate manager correctly? Rerun the WinCC Unified configuration again (with correct certificate and setting) and do a restart. Check this FAQ for basic steps: https://support.industry.siemens.com/cs/de/en/view/109806850 What happens if you load a new test project? Bye Murof |
