7/17/2013 10:24 PM | |
Posts: 24 Rating:
I have installed TIA PORTAL v12 and that option is not shown in the version tia Portal v12. |
7/17/2013 10:50 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
For TIA V12, that is available in properties of a DB(Right click on DB-->Properties-->attribute--> Optimied block access. But before un-check read the following: Setting up block access
What differences should you watch out for between optimized data storage and the standard type of block access in STEP 7 (TIA Portal) V12? |
Last edited by: hdhosseini at: 7/17/2013 11:26 PMLast edited by: hdhosseini at: 7/17/2013 11:18 PM// Link from manual added |
1/31/2014 7:57 PM | |
Posts: 344 Rating:
new question is splittet to what if the "optimized block access" checkbox is checked and grayed so can't be unchecked? |
2/27/2015 12:07 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
