8/15/2013 4:32 PM | |
Joined: 9/27/2006 Last visit: 6/10/2023 Posts: 12040 Rating:
Hello Hugo; These "Block"parameter types are available in TIA Portal, but can only be used with S7-300 CPUs, not S7-1200. What CPU are you trying to program? See the attached document, taken from this manual: STEP 7 Basic V11.0 SP2 Hope this helps, Daniel Chartier |
8/16/2013 9:15 AM | |
Posts: 4 Rating:
Hi! I am working with a S7-1200. I am trying to adapt a program that was made for a S7-400. Thanks!
8/16/2013 9:38 AM | |
Posts: 4 Rating:
In one FC called "Pulse" I found this code, I used this linkhttp://www.plcdev.com/symbol_table_allowed_addresses_and_data_typesto understand what this code exactly does, but I understand nothing. A M 0.0 R M 0.0 A M 0.2 R M 0.2 AN M 0.1 S M 0.1 AN M 0.3 S M 0.3 L MB 3 L MB 1 T MB 3 XOW L MB 1 AW T MB 2 |
8/16/2013 2:51 PM | |
Joined: 7/7/2010 Last visit: 6/9/2023 Posts: 13374 Rating:
If you have s7-200 software, microwin, you can paste this into a STL block, then switch it to FBD or LAD and see if it makes more sense. That's the *easy* way. The other way is to refer to the STL programming reference material: https://support.automation.siemens.com/WW/llisapi.dll?query=stl+programming+reference&func=cslib.cssearch&content=adsearch%2Fadsearch.aspx%3Ftab%3D2&lang=en&siteid=csius&objaction=cssearch&searchinprim=_searchinprim_&nodeid=99&x=16&y=8&cssearchengine=NEW&x=0&y=0 |
science guy |
