1/27/2013 8:41 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
and I need some way to display the countdown time from the timer on the display thank you very much Hello, My suggestion would be using data type "TIME" as time value for timers in S7 1200,You make the field you like in HMI and do the linear scaling for conversion that time field to millisecond.In PLC add all tags gathered from HMI and make the final "TIME" variable. Also read the following topic or search via forum: Entering/Displaying time values in units other than MillisecondsFor remaining runtime, please check this topic:How do you specify the runtime for a timer via an operator panel, or how do you output the remaining runtime? Best regards Hamid Hosseini |
1/28/2013 10:24 AM | |
Joined: 9/23/2005 Last visit: 1/30/2023 Posts: 4177 Rating:
Hi, take a look also at: Sample program: Setting Time setpoint to S7-1200 from KTP /tf/WW/en/Posts/39749#top |
Denilson Pegaia |
