10/26/2021 7:51 PM | |
Posts: 257 Rating:
Hello SIOS Forum Community, In some customer discussions, customers ask us which book they can use to familiarise themselves with TIA Portal Operation/Monitoring. The wish is then often to receive a book that is as efficient as possible for familiarisation. For familiarisation with WinCC Comfort/Advanced/Unified TIA Portal, the following Getting Started can be recommended: https://support.industry.siemens.com/cs/ww/en/view/72927035 (WinCC Comfort/Advanced) https://support.industry.siemens.com/cs/ww/en/view/72927035 (WinCC Comfort/Advanced extended project planning) https://support.industry.siemens.com/cs/ww/en/view/109783212 (WinCC Unfied Panels) However, if you want to get started quickly without prior knowledge, you should book a course at SITRAIN. I can recommend the TIA-WCCM, TIA-WCCM2. SITRAIN can be reached at the following address. Many of the workshops are also available virtually. (www.sitrain.com) Best regards, SIMATIC International Technical Support. |
