2/18/2025 7:24 AM | |
Joined: 1/21/2013 Last visit: 4/19/2025 Posts: 3765 Rating:
Hi, There will be several approaches depending on the items being used. Assuming a polygon is used, you can use the "BorderColor" property. Alternatively, you can simply write a tag and use that tag within the border color dynamization. Kind regards |
2/19/2025 2:45 AM | |
Joined: 11/28/2024 Last visit: 4/16/2025 Posts: 38 Rating:
Hi, Using three polygons, but on selection from the dropdown values the desired border should be highlighted that is tags used for the border will be from the digital outputs and the drop down tags assigned are the input tags. But this approach is not working. Any solution? |
