12/21/2010 6:14 PM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, One way is to use explorer to see when was the last modification. In the other way look at Checking dates of a program modification ... Best regards, Hristo Mihalev |
12/23/2010 7:26 AM | |
Posts: 28 Rating:
thanks but when i open sfc51 it give my protected and open empty page. |
12/23/2010 11:23 AM | |
Posts: 28 Rating:
ok i don't understand the way that you sent it to my exactly,i must wrote a code in sfc51, can you send a specific steps to solve the problem. thanks in advance |
12/28/2010 12:45 AM | |
Joined: 10/7/2005 Last visit: 5/30/2023 Posts: 2965 Rating:
Hello seaf your task seem to relate to Plant widecontrol system relatedMaintenance & Troubleshooting and I suggest you have a look at Auvesys's Versiondogwhich should do what you need and a bit more to help you with your job. There are a few other similar packagesavailable from other companies and while I haven't personally used versiondog, it seems to be one of the better one of the bunch. I hope this helps |
Cheers |
