6/10/2020 9:06 AM | |
Joined: 12/27/2018 Last visit: 10/27/2022 Posts: 4 Rating:
Hi All, I want bring my S210 drive faults in HMI. I'm using S7 1500 PLC. thanks, samson ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/10/2020 10:42:42New subject after splitting |
6/10/2020 12:20 PM | |
Joined: 10/11/2006 Last visit: 2/1/2023 Posts: 5410 Rating:
Hello, please find behind the link the Application, get drive messages https://support.industry.siemens.com/cs/ww/en/view/109479553 |
With best regards, |
6/10/2020 1:30 PM | |
Joined: 2/7/2018 Last visit: 2/1/2023 Posts: 175 Rating:
Hi, you can integrate the error codes of a SINAMICS drive into a HMI project via XML-parser. Therefore you need a xml-list of the SINAMICS S210. If you use a SINAMICS S210 with firmware V5.1 SP1 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109758780 If you use a SINAMICS S210 with firmware V5.2 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109762805 If you use a SINAMICS S210 with firmware V5.2 HF6 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109773739 If you use a SINAMICS S210 with firmware V5.2 HF7 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109780146 How to import the error messages in a HMI-project you can get information at following application example: https://support.industry.siemens.com/cs/ww/en/view/77467239 Best Regards, |
