6/6/2023 2:44 AM | |
Joined: 10/4/2019 Last visit: 12/24/2024 Posts: 8 Rating:
did you ever find a way to browse tags in a compact logix plc, using your pc as the hmi control , all help i can find, is when you are using an external hmi panel[ not using wincc rt advanced thue ethernet ip general- this only allows you to browse siemens plc, let me know please ---Thanks rdh68 ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/06/2023 08:34:05New subject after splitting |
6/7/2023 6:49 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
Closed cause question posted twice. The second thread with the subject siemens commucation from a pc with a runtime project is published within the conference SIMATIC WinCC (TIA Portal). Jen_Moderator |
