10/2/2014 1:03 AM | |
Posts: 90 Rating:
Hi. I'm trying to communicate between two S7-300 with S7 connections in Ethernet using BSEND and BRCV blocks, but with no success. I'm simulation with PLCSIM. Can someone help me to find my mistake, please ? The project is attached. Greetings.
AttachmentS7_pro_1.zip (96 Downloads) |
10/2/2014 10:14 AM | |
Posts: 366 Rating:
Hi, you had there a big problem: your local and partner ID were the same -> this cannot work. I gave CPU315 ID 1 and CPU317 ID 2 and corrected it in FC10 CALL. I also used in both projects SFB12,13. Please try with project in attachment! nice regards
AttachmentS7_pro_1_new.zip (122 Downloads) |
10/2/2014 11:54 PM | |
Posts: 90 Rating:
Hi Kampi. No success with the project attached... ![]() Are you sure that the ID must be different in both CPUs ? I ask that because the answer ofUMENCHOin the following topic: Please, I need help about it !! ![]() regards. |
10/5/2014 10:33 AM | |
Posts: 784 Rating:
Hello Experts, Kindly explain how it works withsame ID's and also with different ID's for both CPUs? Best regards.......... |
10/6/2014 10:23 AM | |
Posts: 366 Rating:
And again: I cannot explain why it works because I'm not the programmer who wrote the Siemens software.. I just can say that I have tried it and it works.. |
