12/24/2024 10:49 AM | |
Joined: 7/12/2022 Last visit: 2/7/2025 Posts: 3 Rating:
Hello, I have noticed a bug with "Symbolic IO Fields". Here’s the issue: I configured fields with text lists and HMI or PLC tags. On the panel, when I click on the list, it shifts position. On the second click, it moves to the top-left corner of the screen. I tested this on both a Basic and a Comfort Unified panel, and the problem persists. It seems to be related to the "Bright Style," as I couldn’t reproduce the issue with the "Extended Style." I noticed this problem after upgrading to Update 4. In simulation mode on PC, the list works correctly. Here is a video showing the problem (the video is not mine): Video Actions already taken:
My question: Has anyone encountered this issue before? If so, what solutions or workarounds do you suggest? Thank you in advance for your help! |
Last edited by: CDL_Jl at: 12/24/2024 10:50:04Last edited by: CDL_Jl at: 12/24/2024 10:54:59 |
1/2/2025 9:31 AM | |
Hello AlanTI, Thank you for your response and the workaround you provided. |
