10/28/2020 5:28 PM | |
Joined: 12/5/2018 Last visit: 9/25/2023 Posts: 13 Rating:
Hi, I've tried to build the image but once copied to microSD the IOT boot correctly I guess (stat led blinking green) but not accessible in SSH at default IP 192.168.200.1 in any of the 2 ethernet ports. Have you tested it? Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/29/2020 08:19:56New subject after splitting |
10/29/2020 10:50 AM | |
I've a basic model of IOT2050. Thank you in advance for the tests! |
11/3/2020 1:04 PM | |
Joined: 4/28/2015 Last visit: 11/22/2023 Posts: 570 Rating:
Strange problem. But as you started bisecting for change that causes the SSH regression for you, could your nail that down to a single commit? In fact, the most suspicious one is https://github.com/siemens/meta-iot2050/commit/16bc4f221de26386b3c6051e0fc05e1eabb3c68b which switches the Ethernet port names under Linux. But you tried both ports already, didn't you? |
