5/11/2020 1:28 PM | |
Joined: 3/17/2014 Last visit: 4/21/2022 Posts: 53 Rating:
Hi jan-k, I'm trying to build the example image as specified in the git repo, but I cannot generate the image only because I get one error on mraa do_dpkg_build. Below the building log:
Analyzing the logfile log.do_dpkg_build.2094 seems that the error starts from Java compilation. Below the last lines from the logfile:
Attached there is the complete logfile of the failure. What can I do? Thank you Davide Siemens Italy
------------------------------------------------------------------------------------------ Attachmentlog.do_dpkg_build.2094.txt (150 Downloads) |
Last edited by: davide_maffei at: 05/11/2020 13:30:12Last edited by: Jen_Moderator at: 05/12/2020 13:35:04New subject after splitting |
5/12/2020 2:26 PM | |
Ok thank you jan-k, I've open an issue on https://github.com/siemens/meta-iot2050/issues/1. I've tried also to build the example-rt-image but I get the same error. But it's docker, I don't understand why. |
