12/23/2015 1:19 PM | |
Joined: 9/19/2013 Last visit: 9/22/2021 Posts: 75 Rating:
[snip]...
But now i must ask a new question about choose SW.
https://support.industry.siemens.com/tf/ww/en/posts/differance-between-wincc-advance-v12-and-wincc-professional-v12/94985/?page=0&pageSize=10 In the link above, you can read these and no differece with WinCC Advanced between Prof.512tag. But Advance is more cheap. And both of isnt runtime. So what is the difference ?
Last edited by: CS Moderator at: 12/24/2015 9:50:26 AMNew subject after splitting |
12/23/2015 2:06 PM | |
Ok i understood finally :) Thanl you for your good explonation. There is no different prof and adv. Because i wont do runtime applications. I will buy advanced version. And the last 2 questions :) "512 PowerTags" : is this about runtime's tag ? and second question is: [snip] ... These were last :)
Last edited by: CS Moderator at: 12/24/2015 9:43:34 AMnew quesiton split to a seperate thread |
12/23/2015 2:21 PM | |
Joined: 5/12/2006 Last visit: 5/27/2022 Posts: 20474 Rating:
Why then the Advanced, in this case you can buy the Comfort insteed of advanced, should be more cheap then the advanced 1.) 2.) Regards Christoph ------- |
Last edited by: CS Moderator at: 12/24/2015 9:44:25 AMrelevant part of the reply splitted to the other thread |
12/23/2015 2:51 PM | |
Thank for all your answers, now this issue is clear in my mind ;) |
10/14/2016 10:54 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4871 Rating:
New question published by helloheaven is split to a separate thread with the subject Can I use Tia Portal winCC Advanced / winCC professional license as Runtime license?. Best regards |
