6/30/2011 10:19 PM | |
Joined: 5/28/2008 Last visit: 11/22/2024 Posts: 4516 Rating: (840) |
Hello, Welcome to Forum To tell you that the selection is correct or not, first fill in the attached questionaire. Then we can tell you also the comissioning parameters of BW500 and test weight as well. Regarding to the values provided of mV for load cells, I think you have to make balancing for the loadcells using BW500. Please read this tip. Hope this helps. AttachmentF2-406R13.pdf (195 Downloads) |
Ayman Elotaify |
