9/26/2017 12:07 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello ESAS.SAB Its not clear, what you want to do. do you want to get access to a running PLC with C++. then look for example at snap7 (http://snap7.sourceforge.net/) or do you want to get access to the engineering System to automate your eningeering from "outside" then you should get Information about TIA Openness. https://support.industry.siemens.com/cs/ww/en/view/108716692 |
9/26/2017 2:19 PM | |
Joined: 7/9/2015 Last visit: 3/21/2025 Posts: 4204 Rating:
Hi, if you use Simatic WinAC ODK (Open Development Kit) you can develope an ODK application in an environment for C/C++ programming such as MS Visual Developer´s Studio. Check this link for more information: SIMATIC WinAC ODK (Open Development Kit)Hope this helps, Regards, Towome |
