2/20/2018 3:14 AM | |
Joined: 4/26/2016 Last visit: 6/1/2022 Posts: 22 Rating:
Hi guys, I want to share a CA Certificate for Gmail, if you have a trouble about that I will give you a attachment of CA Certificate. Because if you don't have a CA Certificate you can't send an email. So, I hope this file can help you and solve your trouble, because I've tried and it work. Note : Please extract file and check validation of CA Certificate. A certificate has always a date of issue and a expiration date. To be able to use this certificate the RTU needs a time between the date of issue and the expiration date. Otherwise the certificate is not valid and the mail provider will deny the request of the RTU to send mails. Thanks and regards, Rijacar AttachmentGmail_Certificate.zip (336 Downloads) |
2 thankful Users |
