10/24/2012 10:08 AM | |
Joined: 12/20/2009 Last visit: 9/13/2021 Posts: 6 Rating:
Dear m.shoaib khatana the idea you said i used before with incremental encoder and it works fine. the difference here the the encoder reading is by degreee,so it read from 0 to 8192 pulse/rev then it resets and start from 0 again. the other thing that i need much faster calculation (max 500ms) as i will use this valve in a pid function thanks |
3/21/2013 1:57 PM | |
Posts: 4 Rating:
Hello, my situation is similar. Can You explain your solution in more details? Thanks
