10/8/2013 8:06 AM | |
Posts: 58 Rating:
See the project attached to this post. if i want to call a block with a any type with a int value of a udt i got a error. someone knows how to fix this problem? Attachmentany-type problem.zip (70 Downloads) |
10/9/2013 2:42 PM | |
Joined: 10/10/2005 Last visit: 11/21/2022 Posts: 1909 Rating:
Hello, your project can not be opened. You can use the any pointer for S7-300/400 CPUs. You can also use the any pointer by S7-1500 if you make your program in LAD. For the S7-1200 CPUs you can use the data type VARIANT. See the FAQ with the examples: http://support.automation.siemens.com/WW/view/de/42603286 With best regards |
10/10/2013 11:04 AM | |
Posts: 58 Rating:
do you have TIA portal V12? same project here with some adjustments. but if i just want to do on a s7-300 a any pointer i can't send a int to this parameter. Attachmentany-type problem.zip (62 Downloads) |
10/30/2013 3:25 PM | |
Hello, see the some examples in refer to indirect addressing with any pointer: http://support.automation.siemens.com/WW/view/de/22422092 With best regards |
