7/29/2020 8:29 AM | |
Posts: 83 Rating: (0) |
Can anyone tell me about CAM module? What is in it and specialty?can we use normal IO module over CAM module? Thanks in advance |
7/31/2020 12:35 AM | |
Please any response will be appreciated |
8/1/2020 7:08 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (820) |
Hello, if you don't have answers, problem can be with your question. What about destination CPU family? Maybe then someone can give you some answer. On other side you can check Forum for similar Topics, here I've prepared something: CAM module Forum Search results |
With best regards... |
11/5/2020 5:29 AM | |
understood it's about positioning output. .any simple answer with example will be great :) |
11/10/2020 5:08 AM | |
yes FM352/452.. what are they about? |
11/10/2020 8:54 AM | |
Joined: 9/23/2005 Last visit: 9/10/2024 Posts: 4689 Rating: (720) |
They switch digital outputs based on parametrized ON/OFF positions and actual position read from an encoder. Advantage over standard digital outputs - they are faster and their cycle is isochronous. More about here. FM352/452 nowadays are outdated and their speed is not making wow effect as it used to be. |
Regards, |
11/11/2020 5:56 AM | |
can possibly use standard digital output module as a replacement for CAM? |
