11/27/2018 7:31 AM | |
Joined: 7/30/2012 Last visit: 4/24/2025 Posts: 335 Rating:
Hello!!! I'm using cam function in D425 if machine in auto mode cam will take place for movement if machine in manual mode cam should off and normal position task will work everything working fine but in manual mode i'm receiving error from simotion 40005 (display 1 reason 3) not able to acknowledge this error before starting of position axis command there is logic to switch off cam (refer attachment) maybe the cam off command not executing properly anyone tell the way to avoid this error ? AttachmentCam.zip (334 Downloads) |
12/1/2018 5:44 PM | |
Hello, Thanks for your reply if u don't mind can you help me to solve this error i have attached cam parameters AttachmentCamParameters.zip (317 Downloads) |
12/6/2018 2:53 PM | |
Joined: 10/11/2006 Last visit: 4/24/2025 Posts: 6009 Rating:
Hello, the error doesn't depend on positioning mode. So you have to check your cam, and settings for cam creation. You can check your program sequence with TO Trace. 9.7.3 Technologieobjekt-Trace https://support.industry.siemens.com/cs/ww/en/view/109757309 |
With best regards, |
