2/27/2018 3:37 PM | |
Joined: 10/11/2006 Last visit: 4/17/2025 Posts: 6008 Rating:
4.2.6.4 Calling up the status of cam tracks and single output cams https://support.industry.siemens.com/cs/ww/en/view/109744600 4.3.2 Parameterizing the Cam Track technology object Configuration data defines the principal functionality of a TO. They are set within the object configuration framework with the SCOUT engineering system and are not normally changed during runtime. It is possible to change configdata. Depending on the configuration data item, the following options are available: ● Cannot be modified online: This configuration data can only be modified during configuration of the technology object with SIMOTION SCOUT. ● Can be modified online, effective after restart: This configuration data can be changed by variable access from the user program. The change does not take effect until the technology object is restarted (see Resetting a technology object). ● Can be modified online, immediately effective: This configuration data can be changed by variable access from the user program. Change is immediately effective. 5.2.11 Configuration data Modifying configuration data at runtime (online modification) https://support.industry.siemens.com/cs/ww/en/view/109749942 |
With best regards, |
