4/19/2012 1:20 PM | |
Joined: 8/31/2005 Last visit: 8/20/2024 Posts: 2198 Rating: (328)
After resetting the CPU (MRES) it loads the program from the MMC. This may look like the CPU didn't reset. To make a factory reset follow this (requires firmware 2.5 or higher): https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=29564002699&Language=en-US&TopicId=24570788363 |
4/19/2012 1:26 PM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Or if you have a new MMC... Best regards, Hristo Mihalev
Joined: 7/18/2011 Last visit: 10/9/2023 Posts: 521 Rating: (91) |
Hi Tjome, Can you upload the program to see what's causing the last error ? Kind regards, BV |
4/19/2012 1:27 PM | |
Posts: 30 Rating: (1) |
Now I know. I will try that nexttime. Now it ok, but realy good to know - I was doing " my" MRES at least 10 times today ( but I never check online if its realy was "clean", because I was for shure that CPU was cleard each time). |
4/19/2012 1:30 PM | |
Here it is |
