4/17/2018 7:57 PM | |
Joined: 9/27/2006 Last visit: 3/14/2025 Posts: 12344 Rating:
Hello geddawy; The Helmholtz CAN 300 PRO is a S7-compatible module (it installs on a S7-300 rack), it supports CAN, CANopen master or slave and SAE J1939. Here is the datasheet: In this Helmholtz webpage you will have information on the handling blocks for the CAN 300 module, and the configuration software required (see the attachment below, taken from the CAN 300 Pro manual that you find in the Documentation tab). You can also look for a distributor through their Contacts link. https://www.helmholz.de/en/products/fieldbus-applications/can-bus/communication-modules/can-300-pro/ Hope this helps, Daniel Chartier |
2 thankful Users |
