10/5/2021 6:22 PM | |
Joined: 9/20/2017 Last visit: 1/9/2024 Posts: 1 Rating:
Can you control 2 PLCs to a 7' Basic HMI panel? It show having wired connections in the devices and networks screen, but in the connections screen, it only shows plc_1 and will not allow to add another. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/06/2021 10:27:19New subject after splitting |
10/14/2021 2:21 PM | |
Joined: 8/3/2009 Last visit: 4/24/2025 Posts: 15350 Rating:
Hello GatewayCTC You can use up to 4 PLC connection s at the same time with a Basic Panel 2nd Generation: https://support.industry.siemens.com/cs/ww/en/view/109798671/78120935179 Bye Murof |
