7/16/2012 11:49 AM | |
Posts: 376 Rating: (57)
Hello Muthu R, If you uses a PC with softwareSTEP5andserial RS232 interface youcan take the PC converter cable with the Siemensorder number 6ES5734-1BD20. The interface assignment of the PC converter cable finds you here: http://support.automation.siemens.com/WW/view/en/13063839 Here a further recommendation. Köster-Box (PC-S5-Interface) Interface for programming Siemens S5-PLCs with the PC. The Kösterbox converts the RS232 signals of the PC into TTY signals (20mA) of the automation system. • The box is full duplex, send- and recieve channel, • the box is active for programming S5 90-115U, • for S5-135/155U and CP or acting passively with other cable, • the box has its own power supply with galvanic separation Unfortunately, I do not have any link to it. Please use the search of Google. Asname you can use "Köster-Box". Or look here. If your PC does not have any serial RS232-interface.A solution for PG/PC - USB. http://www.process-informatik.de/produkte/pg-usb&lang=en_ Regards Azteke0110 |
