10/1/2009 4:43 PM | |
Posts: 24 Rating:
Dear sir, i have the following network: 1-CPU 315-2DP 2-CP 343-1 3-Three MP377 4-Two Stations : -engineering station (included S7 5.4, WINCCFLEX 2008) -Workstation (RUNTIME WINCCFLEX 2008) i want to make Ethernet network between all of this items and as i know it can be done but i faced some problem in communication drives in WINCCFLEX 2008, when i select S7-300/400 its appear in orange color and i cant edit in the IP address. So kindly can you tell me how can i make the configuration in WINCC FLEX to fit my requirement as you will see in the attached files. Also if i have changed in MP377 screens Can i download direct throw Ethernet to MP377 from my Engineering station? or i have to connect the serial cable to dowenload the modification. Finally thanks Attachmentnetwork.zip (52 Downloads) |
