2/22/2009 9:27 PM | |
Posts: 12 Rating: (0) |
i want to generate a password by WinCCand the user type it again can i make this function with WinCC? |
2/23/2009 3:51 PM | |
Joined: 9/27/2007 Last visit: 12/18/2020 Posts: 993 Rating: (102)
Hi Yes you can do this with global script. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
2/24/2009 9:56 AM | |
Thank you mr.cumulus can you help me to learn global script? |
2/24/2009 7:04 PM | |
Hi monmon2005 sorry, but how should i answerthis question:
What do you want or need? How scure it should be? Is the password for... ? I miss in this questiona lot ofinformation, that everyone can help you.
You can write C- and VBS-scripts, so you need C- or VB-programming skills. necessary adjustments can you get here, when you post the sourcecode. The first problem i see is the security of your password, if you use it in real life. Sorry, how should i help you? Do you have a concept ? Tell us details of your problem. regards cumulus |
3/3/2009 11:27 AM | |
Hi Ok, thats the "over all" descibtion, with what part do you have problems? To generate a password, you can use the date, the time and the parkingPlace. Calculate a little with the values and show and save this as password. Thats very simple and good for testing. regards cumulus |
