3/9/2011 9:19 AM | |
Posts: 4 Rating: (0) |
Hi All, Please help me Can I replace CPU313C-2DP by CPU315-2DP, if yes, how we do it. if now, why? thanks! Splitted from CPU replacement. |
3/10/2011 2:49 AM | |
Marcjan, thank you for your repply, AttachmentGraveur.zip (259 Downloads) |
3/10/2011 12:49 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715) |
The replace thing won't work Attachmenthowto.pdf (396 Downloads) |
Last edited by: Marcjan at: 3/10/2011 12:56 PMLast edited by: Marcjan at: 3/10/2011 12:53 PMadded some more. Problem solved? |
3/11/2011 5:56 AM | |
Hi Marcjan, Thank you so much, I work folow your help, but when I save and compile, it display Write error, and the programer is deleted. Please hepl me!! |
3/11/2011 7:27 AM | |
Joined: 3/21/2006 Last visit: 9/10/2024 Posts: 10228 Rating: (1181) |
Hello, It is a very strange message in your case. Take a look there -HW Config Error. Best regards, Hristo Mihalev |
3/11/2011 8:41 AM | |
At first i had some trouble with your program too (thought it was my system), got messages about write protection. I did a save as (new name) and then i was able to work with the new file. Attached your progam with the new CPU, please check everything carefully, cause i just picked one of the many 315 cpu's. AttachmentGraaf.zip (277 Downloads) |
Problem solved? |
3/15/2011 2:53 AM | |
Hi Marcjan, Thank you for your suppot, I will do it now . Thanks again! |
