9/1/2006 3:14 PM | |
Posts: 8 Rating:
Arr I see it now thanks I'll get it a try... Thanks |
9/4/2006 10:15 AM | |
Joined: 9/1/2006 Last visit: 8/28/2023 Posts: 192 Rating:
I don't know how HyperTerminal works... I think i can't help you further with that. There are a lot of ways to send/receive datatoa PLC (likethe OPC you mentioned). But then you need another program as interface to communicate with the OPC server... The choicedepends on what you use it for, i assumed you wanted a low cost way to send/receive a string to the PLC since you tried HyperTerminal. May be a google-search can bring you a simple Visual Basic or Cprogram that handles some UPD-communications as an example and then create a small program with VB/C yourself. A program like Ethereal can help to debug the ethernet communications (www.ethereal.com) good luck! |
